need help with a b16a2 swap into a 93 civic hatch
cruzy25
i traded for a 93 civic hatch and it has a b16a2 in it and i dont no if they swapped id correctly or not the motor is slanted some and vtec dont kick in and i dont no if they swaped the motor over to obd 1 need help
It sounds like the wrong motor mounts were used. You need to make sure that the car has integra motor mounts all around. I'd also begin to learn about how to do swap wiring. Check out our reference section to see how vtec should be wired to the ecu. (make sure you have either a p30 or chipped p28 running the car).
or make sure they didnt do a swap in a automatic wit wrong mounts. that can cause ur motor to lean
