Need Help With B18 Into Crx
pdqcrx
Member
Just got the b18 bolted in. Got down to the picky stuff you always hate. Is the firing order on the b18a1 the same as the original d16? Are Spark Plug wires in the same place on the cap? I see now the cap and rotor button are different but will the wires off the d16 work on the b18? Also my outer boots on the axles are bad. Got new boots but now see that I will need to take the balancer and the other boot off to get to it.(is this the only way) Can you buy new bands for the balancer and a tool to put them on with. I'm also missing a (rubber) bushing on my shift linkage that bolts to the trans. Will I have to get that from the Acura dealer or can it be bought elsewhere.
Help me out guys thanks.
