Need help with B18A1 into 91 Civic Ex
Discussion in 'Civic and CRX - EF' started by 91ef2, Oct 5, 2010.
  1. 91ef2
    91ef2 New Member
    New to the site. Have a few questions. Trying to swap a 1990 B18A1 into my 1991 Civic Sedan Ex. I'm trying to figure out exactly what I need to get this motor running. I have literally took everything out of the donor DA and don't know where to start with swapping into the civic. I have full motor and trans with axels, mounts and brackets, engine harness with resistor box, ecu and radiator. I have purchased the B to EF aftermarket mounts with the shift linkage and I also have the ecu jumper harness and dizzy jumper. I really just want to know what I need to do to get it running. Looked around with some luck but nothing really helpful. Any links or help is greatly appreciated as this is my first swap. Thanks.
  2. D16SiHatch
    D16SiHatch New Member
