Need help with b20b turbo swap
isk8goofyTJ
Hi guys, I currently have a 90 civic sedan lx with a stock d series engine. I'm saving right now for the b20b turbo, and I need as much help and guidance as possible. if someone could tell me everything that i need and everything that i need to know i will forever appreciate it.
So far I know I will need
b20b
turbo kit
transmission
motor mounts
axles
conversion to OBD0 (not sure how to do that)
I know there is a lot more that i need, which is why i need help! Thanks in advance
you'll probably have the easiest time converting the car and the engine to meet in the middle at obd1 and run a p75 integra ls ecu as the base point, and then chip accordingly for your engine/turbo set up.
you'll also need to go dpfi to mpfi.
