need HELP with ecu wiring on inj swap ASAP see attatchments
MIKEB
ECU wiring schematics see attatchments
When Performing A Dpfi/mpfi Swap The Wire Swaps I Have Printed On The Ecm Terminals Do Not Match The #'s On The Plug. So When Someone Says Swap C1 And C2 W/ B10 And B12 Do not Go By The #'s On The Plug. The wiring diagram i got says injectors are on A1,2,3,4 not A1,3,5,7 so see the conversions i made up.
the ecu i purchased is out of a 91 crx hf, it is a PM8 with EGR thats another problem.
also i have wht/red wire @ B12 it goes to interlock control unit
i also learned that B2 is no longer used, it goes to the tandum valve solenoid. so it can be depined and used for b10 (orange)
  • 88-90civic crx wiring MPFI pdf.pdf
  • 89-91 civic wiring DPFI pdf.pdf
  • 91 civic crx wiring MPFI pdf.pdf
