need help with ecu
Discussion in 'Civic and CRX - EF' started by confusedhonda89, Mar 28, 2010.
  1. confusedhonda89
    confusedhonda89 New Member
    i have a 89 honda crx with the d15b7 in it but its running like crap someone told me that it is because i have the wronge ecu in it does anyone know what ecu is the right one for my car the numbers on my barcode on the ecu are 37820-pm6-a080 i think this is the v-tec ecu but i am not sure of that if i had a v-tec ecu on a non v-tec it would make my motor run like crap right because the ecu would be sending the wronge sighnals to my motor right
  2. invisibledemon
    Tn
    moved into your own thread.
    you should get more help this way.
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    PM6 is the ECU for 88-91 CRX/Civic Si model with D16A6 non-VTEC engine - should work fine with the B7
