gizmosrealm
Hey everyone, I'm going to be helping my brother with his swap and I need some help. I've been working on Hondas for a while now and have done swaps before. The last I did was a B18b into a 88 Civic. Anyways, onto the questions... My brother has a 93 Prelude Si. He blew the H23 and picked up an H22a and then attempted to do the swap by himself and his friends. Unfortunately, they ditched a lot of the parts off the H23. They also cut the line from the fuel filter to the rail instead of swapping in the H23 rail. Hopefully he can get the old rail back and buy a new line. To continue... his Prelude is an automatic, will that work ok with the H22? If so, what ECU will he need? Also, since he's using the A/C compressor and P/S unit from the H23, what brackets will he need to effectively mount them to the H22? Basically guys, I'm starting from scratch and need at least a point in the general direction. Any point to detailed swap guides are very appreciated as I haven't found one really useful yet. At least I have the H23's wiring harness in his trunk. Thanks for any help you can give me.
