Need help with harness.
lshatch99
I've got a 99 civic dx, it has a engine swap from a 98 integra Ls. It runs like complete shit and i want to put a new engine harness in it as mine is hacked.
Which harness's can i use?? I know people recommend the ex/si (which i dont know why, the si has a bigger dizzy plug) but can you use other harness's?
Car is 99 civic dx, so it's obd2b. The engine is from a 98 integra ls, so it's obd2a. Which engine harness can i use???
Also, the car has a obd1 jumper harness and is running on a p75 ecu.
Please help!
the harness on the integra is not compatible with your civic
the integra one plugs in at the shock towers... the civic one goes all the way through the firewall
you need to either fix your hacked harness
or you need to buy a new harness for a 6th gen civic and modify it
Yes, but i need to know what harness i need.......
any 99-00 harness?? CD/DX/LX??
sure...
unless at some point you plan on converting to VTEC... then you might want to go with an EX or Si harness
up to you
Alright thanks, i just wasnt sure which harness's i could use.
People recommend the ex/si because they already have the 2 wire iacv, but the si harness has a bigger dizzy plug. I was also told the hx harness is funky and has a 7 wire 02.
So CX, DX or LX harness WILL work, correct?
