Ok i have a 93 eg civic im dropping a 99 ls motor into.....Every mount has worked so far. I have 90 crx si mounts being used for the 2 torque mounts and for the drivers side mount and a hasport eg mount for the passenger mount. Well the rear mount i used the 99 ls mount from the integra but it is to short and cant reach the block. I was curious if any body knows what mount im supposed to use for the rear on an swap like this. Thank you
