need help with radiator fan.....
Discussion in 'Civic and del Sol - EG and EK' started by podagee, Sep 21, 2008.
  1. podagee
    podagee New Member
    wailuku,hi
    my 93' del sol si radiator fan doesnt turn on...i rigged my own switch and lines to the fan but it gets lame flipping up and down so often.dont want to cut the wires cause i dont want to mess the harness up.doe s anyone know the wiring if it needs to be spliced)or the switches and there locations.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what are you wanting ? for it to be just like stock ?
  3. demonboy1300
    demonboy1300 New Member
    Harrisburg,PA
    Just hook it up to switch then, its a lil louder when you just chillin, but w/e the cars on it is too
  4. AHHVTEC
    Alabama
    i thought you already ran it to a switch
  5. podagee
    podagee New Member
    wailuku,hi
    i like em be back to stock cause its irritating flipping the switch.i want it on only when its supposed to be on.
  6. AHHVTEC
    Alabama
    if the fan is fine buy a new fan switch
  7. podagee
    podagee New Member
    wailuku,hi
    where is that located?
  8. AHHVTEC
    Alabama
    should be toward the back of the block kinda at the bottom you will see it going to where fluid travels through
  9. podagee
    podagee New Member
    wailuku,hi
    oh ok thanks guy
