Need Help with Skunk2 intake manifold intsall
ryanintracy101
Ok I have a 98 Integra LS and I got a new skunk2 intake manifold. Well there's a sensor on the top of the stock manifold just to the right of the throttle body and from reading around it's the purge solenoid to the evaporative system. I have no idea what this is. Well the probles is there's no spot for it to hook up on the skunk2. So my question is where do I hook this up to?
You don't use it with the skunk2 manifold. If you don't live in an 'emissions' area, just throw it away.
Originally posted by ryanintracy101@Feb 10 2005, 02:15 PM
Thanks but I live in California so i'm haunted by those "emissions"
[post=459125]Quoted post[/post]​
try to rig it into your intake. you know in the intake where there is a line from the valve cover to the intake, put the hose from the purge canister there. then just put a little filter on the valve cover.
Yea, I guess you can try to rig it on.
Is th Skunk2 even CARB approved or whatever that special thing is for califonians.
God I love PA.
