need help with sohc vtec zc swap
Discussion in 'General Tech and Maintenance' started by 90crxSi/Zc, Apr 8, 2007.
  1. 90crxSi/Zc
    90crxSi/Zc New Member
    ^_^ I bought a 1990 crx Si that had a SOHC Vtec Zc swap done to it, When i bought it it had no Vtec solenoid and it had the stock ECU on it, And i was wondering if i put the vtec on it what ECU will i need to use and will i need to get a different wire harness for it?
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You sure it's a VTEC engine to begin with? If it has the stock ECU, you'll need to swap the distributor and get a OBD0-OBD1 conversion harness and a a P28 or P30 ECU.
  3. 90crxSi/Zc
    Ya im sure its a vtec. What car would the harness that i need come out of?
  4. 90crxSi/Zc
    Ya theres a block off plate there.
  5. 90crxSi/Zc
  6. 90crxSi/Zc
  7. 90crxSi/Zc
    I dont have anything done to it yet, so what will i need?
  8. jlicrx
    jlicrx Senior Member
    Colorado Springs
    you need this: Rywire - Online Store
  9. 90crxSi/Zc
    But it says that it cant be used on a Si chassis
  10. 90crxSi/Zc
