Need Help with something on car
Discussion in 'Civic and del Sol - EG and EK' started by Legia22, Feb 5, 2009.
  1. Legia22
    Legia22 New Member
    Alright, so today i was driving my car around and stopped to drop off a book to get money back. Well when i came back outside to start my car, the car would turnover but not fire at all.. It has fuel which i can smell, and i replaced the distributor cap, the rotar, and coil. I already teseted to see if the coil gets power and it does.
    I still not get any sparks from the coil, or the spark plug wires. Anyone know what the problem could be?
    The car is a 94 honda Del Sol, with a a B16A DOHC V-TEC engine in it.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    check to see if your timing belt broke
    1 person likes this.
  3. Legia22
    Legia22 New Member
    The eingine still cranks over, so it can't be the timing belt, it just won't ignite. It has to be electrical somewhere
  4. AHHVTEC
    Alabama
    lol the motor will still turn over with no timing belt
  5. Legia22
    Legia22 New Member
    So, other than the timing belt? What else could it be? Could it be the ECU chip, the gas pump, or a blown circut?
  6. Legia22
    Legia22 New Member
    Opps messed up on the reply up top, the coil its self does not produce any sparks of any type for do the spark plug wirse, but the wires running to the coil is generating voltage
  7. AHHVTEC
    Alabama
    well you said its getting gas so it cant be the pump,so the things i would check would be the timing belt,then i would check the ecu, then i would try a new distributor
  8. Legia22
    Legia22 New Member
    so how do i check if it is the timing belt?
  9. AHHVTEC
    Alabama
    take the cover off and look
  10. Ethan
    Ethan Well-Known Member
    lol
  11. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    just see if you get compression....you dont have to do anything but remove 1 spark plug then, and it will verify that your timing belt is ok or not.
  12. Legia22
    Legia22 New Member
    So could there be a problem with the dizzy at all, even though i can get power to it? I mean its not the fuel pump or anything...and its kinda odd for a car just to all the sudden stop working after 5 minutes of being turned off
  13. AHHVTEC
    Alabama
    well did you ever check the belt. here's a easy was take the distributor cap off and have someone turn over the motor and see if the button spins
  14. Legia22
    Legia22 New Member
    if your talkin about the rotar then yes that still turns,
  15. AHHVTEC
    Alabama
    then i would think you need a new distributor
  16. serrilion
    serrilion In my own little world! VIP
    Vermont
    My GF stalled her Ex Coupe on the Highway 1 day and the dizzy died, it can happen in a min! LMAO
  17. PYSPR
    PYSPR New Member
    Cali
    ur igniter in the dizzy took a dump
  18. Hfiend
    Hfiend New Member
    boston
    yep check the icm
  19. Ethan
    good chance its your dizzy. try switching it with another one just to verify.
