need help with swap problems
Discussion in 'HYBRID -> EG-EK / DC' started by xiong55, Mar 18, 2008.
would an obd1 intake manifold be better for my set up
  1. yes
    4 vote(s)
    80.0%
  2. no
    1 vote(s)
    20.0%
  1. xiong55
    xiong55 New Member
    i have a 95 cx eg and i swap a b18a1 motor into it and its running really shitty. i am using mobile1 motor oil and honda manual tranmission fluid and pumping premium fuel, rite now im still using the obd0 intake manifold. my car keeps dying whenever i let go of the gas and let it roll on nuetral and sometimes it will die when i put my foot on the clutch. it is also lagging power and torque, also when i drive it will bog and choke mostly on high way. if u have any suggestions for me please let me know as soon as u can thanks for your time.
  2. custompainter
    custompainter drive it like U stole it
    central CT
    give it a tune up new plugs, wires, dizzy cap, and rotor
  3. xiong55
    xiong55 New Member
    r u sure that well fix the problem cause im low on spending so i dont wanna just spend whatever money i got left on guesses but thanx for the reply
  4. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Perhaps it's time to take it to a tuner?
  5. xiong55
    xiong55 New Member
    is there any good tuner that u can recommend
  6. Luis998
    Orlando, Florida
    You are going to have to seek out a shop near you. Check online and find a reputable shop to do your tuning.
  7. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Check the basics first. I had similar problems when I finished up my d15b vtec swap, and then I found out I had like 4 or 5 blown fuses.
  8. xiong55
    xiong55 New Member
    yea thats not a bad idea ill check all the basics first thanx if anyone else have an opinion please reply
  9. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    I would personally make sure there is an obd1 IM/TB as well as an obd1 distributor IF your harness/ecu is setup for obd1.
  10. xiong55
    xiong55 New Member
    whats the IM/TB? the distributor is for sure obd1
  11. eg6sir
    intake manifold, throttle body
  12. xiong55
    xiong55 New Member
    the IM/TB is an obd0 is that the problem then?
  13. custompainter
    central CT
  14. BrutalB83
    Rochester Hills, MI
    All of that stuff should be mandatory for a motor swap anyway. You don't know when the maintenance was last done on a swap motor, so why wouldn't you give it a tune up while you have the chance?
    A timing belt and water pump wouldn't be a bad idea either. That way you know for certain the last time it was done...
  15. custompainter
    central CT
  16. xiong55
    xiong55 New Member
    i got new plugs on it. but a couple of my friends say it might be my distributor that is bad and does anyone know why it keeps lagging on every gear when i hit 2000rpm
  17. xiong55
    xiong55 New Member
    does anyone else know what might be the problem?
  18. tf fo sho
    tf fo sho New Member
    honestly, it sounds like a air/fuel ratio problem to me which means take it to a tuning shop unless you have a ecu management system and know what your doing.
    also, changing the plugs wouldnt be a bad idea..
  19. UNDR8D
    UNDR8D ...has a job!
    8OH!5
    What ECU and harness are you using?
  20. xiong55
    xiong55 New Member
