Need Help With Vtec Oil Switch
MLBC51
THE WIRES COMING OUT OF THE VTEC OIL PRESSURE SWITCH ARE BLUE/BLACK....AND BLACK...I KNOW BLACK IS THE VTEC GROUND, BUT OFF THE SWITCH, WHERE DOES IT GO AFTER THAT I NEED TO WIRE THAT AND I DONT KNOW WHERE IT RUNS TO, ANYONE WITH KNOWLEDGE LET ME KNOW
Pin D6 on the ECU
Or... it could be A4, I forget...
Wanna make it easy on yourself?
Splice open, but don't cut your VTS wire at the ECU,
Go ahead and CUT your VTM wire(VTEC oil pressure switch) FROM THE ECU splice it to the open VTS(VTEC solenoid)...
This will defeat your VTEC oil pressure switch and eliminating what I would imagine is a worthless part.
Again, you're going to connect the wire from the ECU that is your VTEC oil pressure switch to the vtec solenoid.
