need help wrong dizzy ?
Discussion in 'HYBRID -> ED-EF / DA' started by trippsef9, Mar 30, 2013.
  1. trippsef9
    trippsef9 New Member
    ok I really need help need the car running by Wednesday to get to work.
    i got a 90 ef si with a b18a1 swap obd0
    the car starts right up everytime. the only thing is that when i give it gas it will just bog out and cut off and eventually die.
    i tried checking everywhere for a vaccum leak but cant find one.
    i just swapped the motor in. it had a bad b18 in it before that was doing the same thing.
    so i used the same manifold and dizzy tranny all that just changed the longblock. i did however notice that the dizzy that is on it is a d16 dizzy. not a b18 one.
    will that be my problem? or could it be something else?
    ecu codes sometime change but mostly throws
    map sensor
    baro sensor
    and intake air temperature
    i already tried a different map sensor
