Need Help!!!!
Discussion in 'HYBRID -> EG-EK / DC' started by boosthatch, Sep 28, 2003.
  1. boosthatch
    boosthatch Junior Member
    I have a 98 civic and recently swap a 95 gsr motor into it i got a obd2 dis.alt.and ecu. when the engine start it idle real low like 500rpm and missing real bad and then on top of that mess vtech dosent engauge can someone help me with my problem thanks :worthy:
  2. h22bubbleback
    h22bubbleback Senior Member
    North Jerzey
    what kind of ecu and distributor do you have?
  3. boosthatch
    I have a p72 and i 97 gsr dis.
  4. noobvang
    noobvang Senior Member
    Twincities, MN
    Do a tune up and check your timing. replace the spark plugs, plug wires, dizzy cap and rotor. Check timing if its correct.
  5. pissedoffsol
    which p72? there are both obd1, obd2a and obd2b p72s.
    http://www.hondata.com/techecuid.html
    which does yours look like?
    and, its VTEC. Notice, no H. pop your hood, and it will tell you that over and over again. :bash: how hard is it to learn that, seriously.
  6. highperboi
    highperboi Senior Member
    Alameda, California
    Samething happen to me, but after like 10 mins or more it jumped to 1000 and it was running normal. i didnt like how it was doing that so i started unpluging shit and plugging things back together to see what it was and i unpluged my evap purge thing and switched map sensors from the one on the car to the one on the engine.
