Originally posted by ivanB16@Nov 25 2003, 08:20 AM What are the fuses or cables that i need o jump to prent the ECU from return my timing to stock?????????????????????
you might have a service connector to jump during the adjustment process. You remove that jumper when you're done, and that becomes the starting point for your ecu. Check your manual.
