Need help!!!
CiviC DriveR
i Have a 1995 Honda civic DX coupe and it has a D16a6 1.6 ltr JDM (not V-Tec) 16 valve with a Block that is 88-92. it is an automatic and i was just wondering if i can change it to a 5 speed. If you can please help me it will be greatly appreciated.
try the search button this has been covered time and time again.
looked there and wasn't very much help all i need to know would it be hard on the car i have and if id have to modify the car or the frame?
should be an easy swap. mounts should all be the same. there should be more info on the forum if you search around
wait does it matter what civic i pull it out of or does it have to be the same year? or does it have to be a 92-95 civic model?
no..unless you want to do hydro to cable conversion from an 88-91...
you will need the pedal assembly from the 92-95,the tranny fron 92+ axles to match your hubs and whatever trans you choose.shift linkage from 92-95 civic.
