need help
Discussion in 'General Tech and Maintenance' started by tacodawg, Jun 6, 2010.
  1. tacodawg
    tacodawg New Member
    I am new to the forum .. I have an off road car that I run an 02 v6 that is turboed.. I currntly am running without boost due to the octane of gas I get in Baja. I live in the SF Bay area. I have a problem with it runing very rough. It will not get up over 2500 rpm. It surges very bad and I can not give it any gas.. Is there anyone out there that works on these or know of anyone I can take it too to get it running again. thanks
  2. BrutalB83
    Rochester Hills, MI
    What model of car is this? You didn't say. As for the problems you're having, is the check engine light on? It sounds like you're in limp mode...
