Need Help
Discussion in 'HYBRID -> EG-EK / DC' started by Sniper, Jul 28, 2005.
  1. Sniper
    Sniper Junior Member
    I need help finding out what all do I need to swap a B16 5 SPEED into a 1998 Honda Civic EX w/ an AUTOMATIC D16y8 Motor. I have the b16 motor and trans, What else will I need? Thank You
  2. Sniper
    Many View's, Still No Help
  3. Steve EF Hatch
    Steve EF Hatch Member
    Cali
    axels, ecu, wiring harness, pedal assembly for manual, clutch master cylinder and lots of help :thumbsup:
  4. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
    you got on here figured how to sign up and how to post now
    :search:
    man i am getting tired of telling people to search :chair:
  5. Sniper
    Can I keep my automatic transmission and use it for the engine instead of changing it to a manual? So basically, all I need is the ECU, Wiring Harness, & Axle's. What about Motor Mount's?
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    No, but you could find an automatic B series transmission and use that.
    If you are going auto to manual, you need all the manual parts, pedal set, fluid lines, master cylinder. You need a custom auto to manual mount from HAspot, or one of the other on line places, unless you can weld. And you need to rewire the lock out. Search around here, there are more completet instructions, try the FAQ.
