I have an OBD O LS motor in my 88 HF REX and for some reason when i start it, it just keeps reving all the way up, and it wont idol...I know all the fluids are right and the ECU wont throw a code....Can any one help
did you keep your orriginal wiring if so on DPFI which i believe you had with your previous engine the Throttle position sensor or (TPS) spins the opposite direction to fix you just which the two of the three leads i think GRN and RED don't hold me to this
i think thats your problem if its not that then i shall shoot my self in the big toe with a blow gun lol
as for the reason your not throwing a code i have no clue
