Need Help
sick4door
sup ppl am new here and wanted to know if anyone could help me out . I recently bought a 00 gsR shell i put a 96 gs R motor in it but its giving me alot of problems first of all i saw white smoke coming out the motor then the car didnt want to stay on so i took it to some shop and now the car stays on but it idles up and down then when i try to turn the car on yesterday it didnt want to turn on i put the key in and everything works but wen i turn the key everything just cuts off. Can someone help me !!
first thing i would do is get a new battery then i would check for a vacume leak to fix the idle if you dont find one then i would start to look at the iac sensor
i did get a new battery and i check the vaccums and being that the shell is a obd2b and the motor is a obd2a is there anything else i need to change besides the wire harness
