need hlep
Discussion in 'General Tech and Maintenance' started by h22eghatch310, Mar 23, 2009.
  1. h22eghatch310
    h22eghatch310 New Member
    i did an h22 swap on my eg hatch the damm car started drove it around the block started to spit out oil with the dis cap i got a new dist new gas filter new wires the car has spark has gas presure but still will not start what can i do next to start it / :mad::mad::mad::mad::(:(:(:(
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    english?
    longest run on sentence ever
  3. h22eghatch310
    dude sorry iam stressed out i need to get my car running.
  4. reckedracing
    NY
    where did the oil come from? and why did you buy a new distributor?
  5. h22eghatch310
    it came from the dist cap
  6. murray195
    murray195 Member
    Calgary, AB
    You put a new distributor on it after the last one had oil blow through? Why did you get a new fuel filter?
  7. h22eghatch310
    it needed one well i just took the fuel rail off and one of the injectors is really dirty . think that might be the prob in starting what you think <>?
  8. caboose
    caboose USDM to the bone
    Hamilton, MI
    Are you sure that you put the spark plug wires back in the correct order?
  9. h22eghatch310
  10. h22eghatch310
    what you guys think ignition coil .?
  11. h22eghatch310
    how do i put up pics of my rides >?
  12. h22eghatch310
    does any one have a picture of how the wires go on ???
  13. murray195
    murray195 Member
    Calgary, AB
  14. h22eghatch310
    a pic would help alot and also i been reading about the crank does it need any wireing to the engine harness>?
  15. caboose
    Hamilton, MI
    Don't worry murray, I have the assist
  16. caboose
    Hamilton, MI
    What are you talking about? Crank position sensor?
  17. XLITTLEIRISHMANX
    XLITTLEIRISHMANX New Member
    B16B swap in my 94 del sol
    I wanna do a b16b swap in my 94 del sol. Currently has the d16z6.
    Is it possible? If so how exspensive to have it done?
    Thanks!
  18. caboose
    Hamilton, MI
    Only if you start your own thread
  19. 92hatchF22a
    92hatchF22a New Member
    new york
    you also could have the dirsbuter in the wrong location. which would cause you to advance or retard your timming causeing you problems. i have see this problem more then once after a new distrubuter was installed. check it out.
  20. h22eghatch310
    thanks for all the help well i got a light for the injectors and it seems that they are not geting a sginal to release fuel . what do you guys think it might be i know for sure its not the ecu i put the ecu in my other hatch and it starts right up
