Need info about swap
Discussion in 'Civic and del Sol - EG and EK' started by Civicyard, Feb 7, 2012.
  1. Civicyard
    Civicyard New Member
    I purchased a Jdm b18c1 and LSD tranny for my 94civic ex with d16z6.it has harness and ecu but obd2. What harness do I use and what other parts do I need to purchase to do swap? Axles, different ecu? Mounts? Please help never done a different engine swap and I don't want to run into a ton of problems
  2. RHDism
    RHDism Right Hand Drive guru
    The search option is going to be your best friend.
    On a quick note, its a fairly simple swap.
    Pick yourself up some B series axels and an OBD2 to 1 ECU jumper. Maybe even a set of hasport motor mounts.
    Ship me your p28 ecu and harness, and I will guide you through it all.. =0)~
  3. Civicyard
    Iim still waiting for engine tranny to get here. Will my motor mounts fit? I heard they will except the back mount. And b series axels and a obd jumper is all I need? Do I need to put all my sensors on new motor?
  4. Civicyard
    I spent all my extra cash on this so I don't have much left. Need my car running as cheap as possible I can upgrade other stuff that needs to be done later. I just totally my ek hatch and need my car asap
  5. Civicyard
