NEED Instruction on air/fuel gauge
Discussion in 'Civic and del Sol - EG and EK' started by sant0r023, Nov 14, 2006.
  1. sant0r023
    sant0r023 New Member
    i have an 00 civic with a 99 gsr full swap and im installing an auto meter air/fuel gauge. i need to know what pin on my ecu is the o2 censor wire, if that is the correct place to attach it. thanks
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    Go to the reference section and look under OBD2b ECU pinout and look for primary O2 sensor SIGNAL.... Not heater.
  3. ONELIFEMOTORSPORTS
    ONELIFEMOTORSPORTS TURBO LAG=foreplay
    naptown
    if you dont install it with a wideband O2 it is useless!!! lean rich stoich rich lean more lean stoich rich is what it will do!!!
