Need Java help now
Discussion in 'Members' Lounge' started by Capt. Orygun, Jul 8, 2004.
  1. Capt. Orygun
    Capt. Orygun Win the Day
    Oregon
    Okay so without going into detail the Air Force uses a web based maintenance reporting program to all the work which is done on the planes and there components. This program requires JVM1.4.2_04, and as I've learned you can't have some old version installed as well because it fucks up performance. Problem is a few components of JVM1.4.2_03 were still installed. I tried to go to add remove programs and get rid of it from there, I got an error message saying it couldn't remove it because it could not locate the uninstaller. Again no biggie, I re DL the file so I can get the uninstall file and be rid of it, after reinstalling it I have two _03 icons in my add remove programs file (?!?) neither of which can be removed for the aove stated reason. Worse yet I have two Java plug ins (_04 and now _03) in my control panel and I don't know how to get rid of the _03 plug in which effectively disabled all Java use on the system. HEEEEEEEEEEEEEEEEEELLLLLLLLLLLLLLLLLLPPPPPPPPPPPPPP!
    PS: I tried to unistall it manually in the c drive, didn't change any of the above mentioned problems...
  2. pissedoffsol
    java sucks.
    use php
    format your machine :)
  3. Tonyd0821
    Tonyd0821 Banned
    lol i dont think the entire airforce is going to change it's policy because the owner of hondaswap.com says so :p
  4. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    They might... depends on how indecisive the gov't feels today.
  5. corvetteguy
    corvetteguy Senior Member
    Bristol ,CT
    Can you do a system restore roll back to before the date you first installed it? Maybe TweakUI can get rid of them?
