need more info before i start my mpfi swap
Discussion in 'ECU's, Electronics, and Tuning' started by podagee, Jan 13, 2010.
  1. podagee
    podagee New Member
    wailuku,hi
    okay, i keep reading that before you do a dpfi to mpfi swap you need to change your ecu to a pm6-pm8.i have a pm5 if im correct.in the how-to's it doesnt say to swap out the ecu.so now im wondering if i really need to or i dont have to.and i also see that some say you need the throttle cable,once again,the walkthrough doesnt mention nothing of it.i need someone who has successfully did this swap to let me know what i need to complete it.im doing my 91 hatch dpfi to a 92-95 mpfi swap.just stock no V-tech.
  2. podagee
    podagee New Member
    wailuku,hi
    oh,and can i use the fuelline from the 92-95 from the filter to the fuel rail?or which can i use?
  3. ef9obsession
    ef9obsession New Member
    ef9
    the ecu you'll need is the pm6(civic/crx si ecu), , and yes you can use the 92 civc fuel line as long as it fits the fuel rail correctly,
  4. ef9obsession
    and yea you don't need a new throttle cable, just need a new throttle cable mount that holds it correctly to the throttle body. and you need the pm6 because it controls fuels and you'll need to wire it to the register box with also connects to the fuel injectors
  5. tjweberhonda123
    tjweberhonda123 New Member
    iowa it sucks
    wat size injecters im doing the same thing and need help
