5speed4life
Ok, I am finishing up my wiring harness right now, and im working on the dizzy plugs. I converted the car to obd1 with a p28 and jumper harness. Im using the obd1 dizzy in this swap, and have it all wired up except for the solid white wires on the plug. There are two coming out of the harness, but only one on the dizzy. One is shielded along with the rest of the dizzy wires, and the other is not.
Witch one do i use, or do i use both? or does the other one go to a diffrent color wire (there are 2 or 3 other ones i was gona run straight to the ECU, that i have to add)
