Need Opions
Discussion in 'Forced Induction' started by Ractive78, Mar 26, 2003.
  1. Ractive78
    Ractive78 Senior Member
    Virginia, USA
  2. LordJ
    LordJ Junior Member
    FL
    you can but it will require alot of modifications to make them work, like an
    exhaust manifold and pre cat eliminators to fit whatever vehicle you plan to
    put them in
    the ihi turbo kit is good for 1200 hp, its easily 30+ psi of boost
    to fully utilize the ihi turbos, you will need forged rods and pistons, the
    1200 hp fuel system, some type of standalone ecu like the AEM.a twin disk
    carbon carbon clutch. a boost controller,egt and boost gauges a wide band o2
    sensor, laptop, a full exhaust system. a front mount intercooler.ctc
    motorsports coil pack,1000cc injectors, kormex posi unit., some type of
    suspension to hold the power to the ground like the teins.that should give
    you a start of what it will require for the ihi turbo kit.
  3. Ractive78
    Virginia, USA
    For now im just going to run it around 8psi"stock internals" Around what rpm does it spool up? And with 8 psi could I use 450 dsm injectors, with my stock reistor box"1991 integra"?
  4. pissedoffsol
    :bash:
    you don't have a fucking clue do you?
    Ractive, doesn't listen to this guy.
    the auction is over, and its kinda late- but that turbo is not very big.
    IHI makes a good turbo, but they are NOT very big. IHI's came stock on the old turbo T-birds, and a few other cars. its about the size of a t25 - t28 or so... it will make out around 200 horse. 1200 my fucking ass.
  5. civicb18
    civicb18 Member
    IOWA
    ROFLMFAO, b you always the one to give the response and the best/funniest ones at that. thanks for the humor and good responses
    p.s. just thought i would give my $.02
  6. LordJ
    LordJ Junior Member
    FL
