Kyle21nluvnit
Ok I have a 96 accord with a 93 h22 with a P13jdm ecu. The motor is fully in the car and it wont start. I have fuel and compression but no spark. So I have done some serious electrical testing to make sure all my wiring is good. It is but I would like someone to check my specs if you could as I dont have a fully functioning car to compare it with.
For My Wiring: (All are from the connector at the dizzy to the connector at ecu with both unplugged)
Ignition signal wire 0.1ohm
CKP signal wire 0.1ohm
TDC signal wire 0.1ohm
CMP signal wire 0.1ohm
all grounds were 0.1ohm as well
Signal Wires: (This is measuring from the connector at the dizzy to ground with the ECU hooked up, and connector at dizzy unhooked)
Ignition signal wire 26.3kohm
CKP signal wire 8.91kohm
TDC signal wire 8.18kohm
CMP signal wire 8.96kohm
Sensors: (This is through the actual sensors unless otherwise noted)
Ignition control module OFL(Measured to ground)
CKP 373.3ohm
TDC 285ohm
CMP 367ohm
Reference Voltages KOEO: (Measured at connector at dizzy)
Signal wire 4.96V
CKP 0.407V
TDC 0.783V
CMP 0.450V
Like I said if anyone could check these for me or has an idea where to look I would really appreciate it. The measurements through the coils are all good I checked them with a known good coil.
CKP 373.3ohm
TDC 285ohm
CMP 367ohm
Signal wire 4.96V
CKP 0.407V
TDC 0.783V
CMP 0.450V
