I have a 91 hatch with a zc in it and i was wondering if anyone knew what my options are as far as tuning. the cheeper the better.
thanx, i appreciate the help. idont mean to hassle you but, any good suggestions as to where i would get those
hondata I JUST ordered a hondata set up, here's the costs: Burn1 ProgrammerSo I could write my own chips, but if there's a tuning shop by you, they can do it for you. Be careful adjusting air/fuel ratios!! BURN1 Flash-n-Burn USB-Based Chip Programmer [BURN1] - $85.00 : Moates.Net $85.00 2Timer ROM SwitcherThis lets me have 2 air/fuel maps set up. 1 for race, 1 for fuel econ. Keep in mind you can only change profiles while the car is off. You might fry you ECU otherwise. Comes with a chip. 2TIMER - $30.00 : Moates.Net $30.00 Hondata S200Base system. If you order a new one now, they all have datalogging and 3 step rev lim. You wont need to buy it extra. s200 $295.00 Hondata ROM Editor V3Only if you get the programmer, will you need this program to write the chips. s200 $200.00You need a laptop for this as well, or a Palm PDA with OS 3.5 or higher. Welcome to www.moates.net! : Moates.Net has everything! unless you want hondata
hondata doesn't work on obd0. ignore all that. moates.net is a good place to get some gear for tuning
yea i got a 91 hatch and i use turboedit with no problems. and if your running boost i highly recomend a wideband o2 sensor
