Need some good advice
Discussion in 'Civic and del Sol - EG and EK' started by charger11213, May 26, 2008.
  1. charger11213
    charger11213 New Member
    Hey whats up im new to this web site and new to the honda game i need some advice on my problem.
    I have a 1995 honda civic D 16 vetc And its over heating because the fan will not come.
    I change the Thermostat , I change the Engine Temperature Sensor , I change the cooling fan relay
    I drain the old Antifreeze, Put new Antifreeze in the car bleed the system for air bubbles but the fan wont chip in.
    I took a wire and ran it from the relay box to the battery and the fan turned on fine.
    Can some 1 please help me out with this matter.
    Ok i have another question i have a leak in the radiator
    can that cause the car to over heat
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    fuse maybe idk you have semed to check it all out. does it over heat
  3. charger11213
    yes it over heats is there a fuse for it and where is it
  4. AHHVTEC
    Alabama
    just check all the fuse under the hood and dash im not sure witch one it is
  5. charger11213
  6. charger11213
    anybody else can help me with this
  7. charger11213
    bump bump bump please help me
  8. delsol88
    delsol88 Blinker Fluid Specialist
    JC,MO
    well to see if the fan works at all you can try to hard wire the fan directly to the battery for a few seconds and see if it runs, your motor could be burnt out.
  9. AHHVTEC
    Alabama
    did u not read his first post
  10. charger11213
    bump Bump Bump Bump Bump Bump Bump Bump Bump
    Help Please
  11. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Check the fan switch/relay and associated wiring. Check fuses as well. If you put current to it and it turned on, than obviously the fan is operative, it just isnt turning on when it needs to.
    I think you need a new fan switch.
  12. LS_VTEC
    NJ
    1. Disconnect the negative battery cable.
    2. Remove the fan switch and disconnect the wire connector.
    3. Test for continuity as follows:
      1. With the switch in the OFF position, there should be no continuity between any of the terminals.
      2. With the switch in the LOW position, there should be continuity between terminals 1, 2 and 3.
      3. With the switch in the MED LOW position, there should be continuity between terminals 1, 2 and 4.
      4. With the switch in the MED HIGH position, there should be continuity between terminals 1, 2 and 5.
      5. With the switch in the HIGH position, there should be continuity between terminals 1, 2 and 6.
    4. If not as specified, replace the fan switch.
  13. LS_VTEC
    NJ
  14. charger11213
    Thanks i will give that a try asap
  15. LS_VTEC
    NJ
    Let us know if it solves your problem. If it does, + rep me because I am the mannnnn. ;x
  16. jdmthathoeee.
    jdmthathoeee. the sky is the limit.
    Rome.
    haha.
    atleast you spelled adviCe right.
    my dumbass spelled it wrong....
  17. charger11213
    My rad has a leak can that cause the fan not to come on and the car to over heat
  18. AHHVTEC
    Alabama
    it can cause it to over heat
  19. svaby
    svaby Drive and Ride A Honda
    Ohio
    the fan won't have anything to cool if it's leaking all out :D
  20. charger11213
    Ur right but its a slow leak and there alot coolant in the rad
    i have an new rad i will see what happens when i change it
    tomorrow and change the fan switch.
