I have yet to actually see one of these things, maybe you are throwing code 1 and 3, that would be o2 and map sensors
I checked my alldata for the heck of it,
1 reset ecu
2 turn key to run position but do not start
3 check for mil
then it says if the mil is not on then it is an intermittentfailure, but if it is on to replace the ecu with a known good unit.
if the mil does not come on with the known good ecu then you have to replace the ecu.
The BARO sensor is built into the ecu, so I think that you did break something.
