Need Some Help On H22 Accord Swap
Discussion in 'HYBRID -> BA-BB /CA-CD' started by swlltom, Mar 13, 2003.
  1. swlltom
    swlltom Junior Member
    I am swapping an h22 in an 94 accord. The old motor is out. The h22 doesn't have any drivers side mount, do i need to buy mounts for an h22 or do i swap out the mount and mount bracket from the f22?? I knnow i know i need to use the search but i couldn't find anything on it,, also is there any wires that i need or move, thank s alot in advance,
    tom
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    When I did my swap, I used the engine half of the mount from the Prelude, and the chassis side mount of the Accord, and frankensteined them.
    You'll have to run VTEC wires if your Accord isn't an EX, a knock sensor wire, and then switch pins A6 and A11 at the ECU.
