I go boosted GSR, start with more, end with more.
Everything is pretty relevent. The GSR swap is about a thousand more then the LS swap.
So...as my dad always says, "Six is half dozen of another"
Sure, if you just take the first thing you find, I have seen GSR swaps for less than a D15, it's just a matter of where, and how hard you look. Regardless though, it still stands the GSR is going to be the better motor, and if he doesn't get around to boost, it will be more fun than the LS.
dude if you're asking questions like, "which motor is best" and "what parts do I need" 'will it bolt right in" etc. etc.
you've got a looong way to go before you build any turbo motor, or any motor from the ground up for that matter. Do some research
But if you're really going to do it. Get an LS. Since it has 9:1 compression you can boost it to 10psi all day on stock internals and a good tune. But if you want to boos to 15psi like you said you're going to have to tear up either engine with new everything, so don't waste youre money on a gsr just to replace everything.
