need some help
Junkhatch
ive been searching all morning and cant find anything. i am buying a 91 si ef and am wanting to sawp my d15 out of my eg into the ef. this is including the hydro trans. will everything bolt right up and if not wha needs done to make it work.
thanx for any help i get
I'm going to guess that the car you're buying is obd0 and the eg is obd1? So you'll probably have to convert that stuff...but other than that i'd think it would swap straight in.;)
your stock ef tranny will bolt right to the new motor uses that tranny unless you want to convert to a hydro tranny, you wil need to convert to obd1 and you will need to swap the driver side motor mount off the new motor with the old, but other than that it will drop right in
