need some help..
Discussion in 'General Tech and Maintenance' started by riceburner89, Nov 7, 2007.
  1. riceburner89
    riceburner89 Banned
    santa clarita CA
    Ok its really wierd what happnd. i have a b16a SIR 2 in my 95 coupe..
    i SOMETIMES get a idle that goes from 1k to like 1,200
    sometimes it only last for a couple revs.. and sometimes it will keep going..
    **THIS DOES NOT HAPPEN ALL THE TIME!**
    and it only happnds when i come to a stop...
    any ideas wat u guys think this can be?
  2. rainer1386
    rainer1386 New Member
    does it do it when your a/c is off? cuz mine does that when i stop and the a/c is running but stops revving when i turn it off.
  3. riceburner89
    riceburner89 Banned
    santa clarita CA
  4. CivicCrush
    CivicCrush New Member
    check your iac valve or fast idle
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    that or its a possible vacuum leak
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    not all the time...i knew i kid that had a vaccuum leak in his integra and it revved from 1k to 3-4k and back down..and it just kept doing it
  7. norcalgsr
    NorCal
    Definitely not a vacuum leak.. I would check out the IACV and bleed your cooling system as well to make sure there's no air trapped in the system.
