Need some input
Discussion in 'Civic and CRX - EF' started by Ethan, Feb 21, 2009.
  1. Ethan
    Ethan Well-Known Member
    HELP MAhhh
    Hey guys got some vids. Just wanna know what you guys think.
    D15b2 with auto transmission in a 91 civic dx hatch.
    Car runs fine till warmed up. Then it stalls unless you lightly rev it.
    New Shyt:
    head gasket
    intake manifold gasket
    spark plugs
    wires
    cap and rotor
    Update: Also the CEL comes on sometimes after driving a while.
    but i cant pull a code cause it goes off once the key gets turned on and off.
    VIDEOS UPLOADED AND POSTED BELOW
  2. Ethan
  3. George777
    George777 ^^ Likes Bewbies
    With your mom
    You can still pull the code if the CEL came on. Turn the key to accessories position and pull the carpet back. It will flash any of the codes stored in there.
  4. Ethan
    even if the cel isn't on? im gonna go check.
  5. George777
    With your mom
    The ECU should still flash until you reset it.
  6. Ethan
    Yea so far i got (8) and (16) lol
  7. George777
    With your mom
    TDC sensor and FI system.
    I'd start by checking your timing and your injectors.
  8. Ethan
    lol but here is more. here we go.
    Code 1 - Oxygen Sensor "A" (Primary)
    defective circuit or unplugged / defective sensor
    Code 7 - TP Sensor (Throttle Position)
    Code 8 - TDC Sensor (Top Dead Center)
    Code 16 - Fuel Injector System
    defective circuit or unplugged / defective fuel injector
  9. George777
    With your mom
    I would still check your timing first. Then work your way towards the rest.
  10. Ethan
    Think it might be off a tooth or two? That could also answer why it takes a while to start.
  11. George777
    With your mom
    I'm sure the fuel has a lot to do with the starting part. Timing, too, but take the KISS method and eliminate one thing at a time.
  12. Ethan
    Where the hell are the injectors on dpfi? lol im googling but all i keep finding is shiznit on dpfi to mpfi conversion.
  13. 97hatch
    97hatch ?
    Anderson IN
    sounds like a bad ground to me with all those defective circuit/unpluged codes check ground on water neck
    also the injectors are in the intake under the black box on top
  14. George777
    With your mom
    There should be two--one with a brown "top" and one with a green one. I forget which one is the primary, but they are right under the little black thingy that 97hatch mentioned.
  15. Ethan
    OK ill be right back with a update.
    Update: I'm really leaning towards the timing. I thought it was the problem at first
    but then everyone told me it couldn't be. RETARDS!
    But hey at least i found and fixed a leak while i was looking around the intake.
    http://www.youtube.com/watch?v=xpxYark9ySQ
