Need some LSD
Discussion in 'Engine Building' started by hybrid89, Feb 17, 2004.
  1. hybrid89
    hybrid89 thistownsucks...
    SoCal
    I can get a rippin deal on a 99 CTR LSD. 1. I know the B series tranny's are interchangable as far as bolting up to b blocks, but wat about internally(sp)? What will this LSD fit? I have a Y1 cable right now, will it fit? or will the LSD only fit a hydraulic tranny. If so which one. Thanks
    matt
  2. EGLSHB
    EGLSHB Senior Member
    not 100% sure, but i believe there is a difference between the cable and hydraulic tranny's...
    i don't think it will work, but... you might buy it, then use it for leverage in getting a cable one... like, get a buddy with a hydro trans to buy one for a cable trans, and swap him
  3. hybrid89
    SoCal
  4. 2fastaccord
    2fastaccord Senior Member
    Not positive but I am pretty certain that it will not work.
  5. hybrid89
    SoCal
    what tranny will the CTR LSD fit?
  6. phunky.buddha
    Dallas / Fort Worth, TX
    There are 2 or 3 different bolt patterns for the final drive ring gear, and your LSD must match the stock diff if you want it to just bolt in. I don't know what all the different configurations are- it's been a while since I've peeked inside a B series transmission... but you'll have to check on that first. If it matches yours, you should be fine. Be prepared to re-shim your differential assembly though.
  7. pissedoffsol
    cable diffs won't go on hydro diffs
    and more so
    ls/b16 hydro diffs won't go on gsr/itr/ctr hydro diffs
    the y1 sir lsd, or a quaiffe/other aftermarket are your options.
  8. hybrid89
    SoCal
    so what exactly interchangable with a 99 CTR LSD? GSR Y80/S80?
    matt
  9. pissedoffsol
    the ctr lsd will fit in a hydro gsr and itr tranny.
