Need some wiring help
Discussion in 'ECU's, Electronics, and Tuning' started by smooth_criminal, Mar 16, 2004.
  1. smooth_criminal
    smooth_criminal Senior Member
    I'm swaping in a 99LS into my 96 LX civic. Is there any wires tht i'm going to have to change?
  2. pissedoffsol
    most likely.
    you're going to want to use the 96 harness (well, you have to).
    depending on the ecu, it *should* plug in. i believe 99 tegs' were still obd2a plugged, like your civic.
    other than that, a couple extended plugs will probably have to be done.
    pretty simple though
  3. smooth_criminal
    yeah it's an OBD2A, so everythign will just plug and play. I know i'm goingto have to extend a few things like O2 sensor and a few others .
