Need To Convert From 0bd0 To Obd1, Help!
Discussion in 'HYBRID -> EG-EK / DC' started by airosey, Feb 18, 2003.
  1. airosey
    airosey Junior Member
    Knoxville, Tn
    I just got a 95 b18c1 for my 89 si. I have the b18c1 engine harness and the p72 ecu. I'm trying to find out exactly how to convert, i also heard you had to do some rewiring behind the dash. I would really like to use the stock ecu. I've heard there is adapter, but i've had no luck finding one. I need to find everything i can. I really good site that talks in detail would be awsome. Thanks Alot!
  2. gtpilot
    gtpilot Member
    Take a look here...TJ's Honda - a lot of the stuff applies.
    Kirk
  3. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
  4. solblu
    solblu Senior Member
    Ricer
    You pretty much make an adapter harness for the ECU, or cut and splice in OBD1 connectors, then use your Si engine harness and add, extend, wires and plugs till it's all OBD1. I have instructions for a DX if you want them pm me with your email address.
  5. thedumptruck
    thedumptruck Junior Member
    So would converting it to odb1 for the gsr be pretty much the same as converting it as the z6 instructions say? if so, here's another good link...
    D16z6 swap guide
  6. solblu
    Ricer
    Ya OBD1 is OBD1. Just have to add the extra wires the GSR requires.
