need to know if a 93 h23 prelude motor will fit in a 95 civic hatchback.
Discussion in 'Civic and del Sol - EG and EK' started by h23honda, Aug 21, 2006.
  1. h23honda
    h23honda New Member
    i need to know if my h23 motor will fit in a 95 civic hatch back and wut do i need to do the swap.it a h23 2.3 bored port and polised to 2.4 with skunk 2 cams.
  2. BrutalB83
    Rochester Hills, MI
    Well an H22 will fit in a hatch so I assume that an F22/23 or H23 would fit in also. I'm pretty sure it uses the same mounts as an H22 (can someone confirm that?), so if that's the case then you'd just follow the same procedure as an H22 swap into an EG Civic chassis.
  3. reikoshea
    Dallas, TX
    H23 will fit in the civic with h22 mounts. The swap for the h23 is the exact same as the h22. the h23 is a block that is bored .5mm over and does not have the plumbing for vtec. other than that, its the same engine.
  4. BrutalB83
    Rochester Hills, MI
    Oh, and one more thing, an H-series motor won't bolt up to any D-series or B-series trannys, so you'll need to either swap the tranny as well (which will require a bit of customizing) or purchase an adaptor plate if you plan on using a B-series transmission.
  5. sciVici
    sciVici New Member
    they also carry an h-d series adaptor plate. (dont know why you would wanna use a d tranny on an h) but hey they make it lol.
  6. greygoose
    greygoose Junior Member
    The main reason I see people put the d-series plate on the h-series is the fact that a d-series tranny is cheapier and easier to find than a b-series. But thats just my opinion
