need to know
Discussion in 'Civic and CRX - EW' started by lilcrxthatculd, Nov 4, 2006.
  1. lilcrxthatculd
    lilcrxthatculd New Member
    will the transmission from the d15a3 in my car now work with the d16a1 swap?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes
  3. lilcrxthatculd
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
    no - the 87 Si transmission will not bolt to the D16A1 - to swap the A1 into your car, you need the engine, transmission, intermediate shaft, axles, shift linkage and ECU from 86-89 Integra - easiest to use the 86-87 since it has vacuum advance ignition like the Si, but the 88-89 D16A1 is 5hp more than the 86-87 - to use the 88-89 A1, you will need the 88-89 ECU and you will need to do a bunch of wiring - to use the 86-87 A1, it will plug right into everything and you use the 86-87 ECU - the best way to do it is to buy a mostly complete 86-89 Integra to use as a donor car
  5. AHHVTEC
    Alabama
    my bad i was thinking it was a 88-00 motor:(
