Need to raise my civic!
90B16a1si
Member
My spring compressors are too big to squeeze and raise my coilovers in the front. I want to raise them all the way. Eibach/Tokico. Do compressors exist that can get in there and raise these tiny springs?
I don't get it...you have coilovers correct? Why not jack up the car, take off tire, adjust coilover height. Am I missing something here? Why do you have to compress the springs? Even if your taking coilovers off, most if all that i've ever installed, did not even have to compress the spring. Just simpy took them off.
:withstupid:
ive adjusted my coilovers a few times for corner balancing and never needed a spring compressor.... you are doing something wrong
I can raise them and lower them to a certain extent but I can't raise the fronts all the way up because the spring is pushing down on the adjuster. I lossen it but I can't twist it up far enough without reducing the pressure from the spring. Maybe I am doing something wrong!?
Quoted post[/post]]
as soon as the car is lowered back down off the jacks.. the shock should compress a little and make the spring part touch again.. it should be fine
The spring touches even before the car is lowered off the jack. I think I am going to modify my spring compressors and hope for the best. It will still be installed so it can't explode on my or anything. Wish me luck.
what kind of coilovers do you own? some coilovers have 2 separate bottom pieces that you turn, one to adjust the height and one as a lock.
they are tokico illumina 5's adjustable and the springs themselves are eibach ground control. A allen wrench loosens the ring and I have to use pliars to turn the ring. As I screw them up the spring gets squeezed and resists the turning.
I ended up using a large screwdriver and carefully turning the adjuster little by little. It was a pain but I didn't damage anything in the end.
