I need to know if there is any difference in the transmissions between any integras 1994+... does anything change on them like sensors, speedo output, etc. as they get newer? ie... can I run a 94 trans on a 98 b-series swap in a 98 civic? I found out the hard way that the cable trans won't work in an ek, even w/ the hydro conversion kit...
http://www.hondaswap.com/forums/index.php?showtopic=29829 Did you check here? This is www.hondaswap.com's transmission guide... UnlimitedEK9
