Needing help finding a builder/tuner... Deployed plz help
Discussion in 'Forced Induction' started by tcpappas, Feb 9, 2012.
  1. tcpappas
    tcpappas New Member
    As the title says I'm in need of a reputable engine builder and tuner. After my first deployment I put a GSR motor in my Crx. Long story short, not enough power and not enough money to boost so I stroked out to 2.16 and started to fit a nitrous kit. Then I got short notice orders to deploy to Afghanistan just after getting the engine back into the chassis. Now that im deployed and income is not an issue I want to boost and go for big numbers. Im hoping for the 700 range on q16. Any input as well as help finding a builder that I can have finish the engine while I'm gone and have my friend take it to for tuning would be greatly appreciated. I just want this car finished when I get home. Im located in Ohio, but at this point distance doesnt really matter for a good quality build and tune. Here is my current setup as well as some of the near future plans.
    I obviously have issues with making phone calls, if not for the 9.5 hour time difference from home, the horrible call quality over skype. A few builders have blown me off over this build and I want to find someone that is interested in helping me complete.
    1989 CRX HF
    It is entirely possible I have forgot something but if I think of it I will send another email.
    Block
    B18c bored to take 81.5mm decked as well but I don't remember how much off hand
    Brian crower 2.16L lightweight stroker crank. BC5019LW. 95mm stroke
    Brian crower forged H beam connecting rods. BC6040
    JE 11.0:1 forged pistons with JE ProSeal rings
    ACL race bearings
    Golden Eagle oil squirter blockers
    ARP hardware throughout entire engine
    Head
    B16 head
    Brian crower stage II N/A cams. BC0012
    Brian crower valve springs with steel retainers BC0010s
    Brian crower intake and exhaust valves OE spec BC3010 BC3011
    Blox intake manifold
    Blox 68mm throttle body
    Hondata IM gasket
    GReddy timing belt
    Cometic head gasket
    Exhaust
    Skunk2 cat back exhaust 2.5" megapower
    Drivetrain
    P72 hydraulic trans with factory LSD
    ACT Clutch organic disc with heavy duty pressure pressure plate
    Factory flywheel
    Cooling
    Mishimoto half radiator with custom fan shroud and Full-Race fan
    Fuel
    255lph fuel pump
    AEM fuel rail
    RC 550cc injectors
    Management
    s300 in a p72
    Suspension
    BC racing coil overs
    Skunk2 adjustable upper control arms
    Skunk2 adjustable rear links
    Skunk2 rear lower control arms
    ASR rear subframe brace with 23mm sway bar
    Explicit speed racing front and rear strut tower bars
    6pt roll cage
    Innovative mounts front crossmember
    Brakes
    Si master cylinder and proportioning valve
    Si rear disc trailing arms
    Powerslot front rotors
    OE rear rotors
    Hawk HP plus pads
    Wheels
    Rota Grid 16x7 running 205/45/16 Hoosier A6s
    I have a decent idea of what I want to do upgrade wise but I am always open to other ideas
    Brakes
    Willwood big brake kit and proportioning valve
    DSS axle kit, not sure which one yet
    I want to lexan the hatch as well as the corner windows
    Fuel
    Possibly go to a 8inj intake manifold
    Upgrade injectors
    Full Blown double pump hanger will Walbro 255's
    Convert the car to Steel braided lines with AN fittings
    Fuel pressure regulator
    Internal
    Golden eagle sleeves o-ring'd
    Manley Turbo tuff rods
    Turbo kit
    Full-race non-AC prostreet kit
    Unsure of which turbo to choose
    Hydraulic clutch conversion
    adjustable cam gears
    Clutch upgrade
    Any help will be greatly appreciated.
  2. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    Slowmotion Motorsports in Columbus. They are THE people to go to in Ohio. They've built quite a few record holding drag cars in their full on speed shop.
  3. tcpappas
    tcpappas New Member
    That is who I purchased my stroker kit and other parts through, unfortunately they have been reluctant to reply to any of my emails. I guess ill try again.
  4. double0Si
    Columbus, Ohio
    They get pretty swamped especially during the winter when everyone wants to build for next season. If you ever get the chance I'd give them a call to make sure they get your situation and maybe get a direct email address for the future.
  5. tcpappas
    tcpappas New Member
    I sent them another email, unfortunately with being 9.5 hours ahead of OH in Afghanistan and having poor ability to call back home email is my best chance.
