NEW ARP ROD BOLTS B18A B18B B20B B20Z 1.2-1.8 8mm
94CivicSlow
Brand new set of ARP Rod Bolts for Honda/Acura 1.2-1.8 Motor. .
Made from a premiun grade 8740 alloy chrome moly steel. They are the perfect choice when rebuilding a Honda/Acura 1.6-1.8 motor. A great upgrade for LS/VTEC, CRV/VTEC, High Reving All Motor, or turbocharged application. This material is heat treated to provide a tensile strength in the 200,000 psi range, which is substantially stronger than OEM. Cycle testing shows ARP High performance rod bolts to be nearly 5 times more reliable than stock bolts. Don't cut coners on your next rebuild!
Fits the following applications:
Honda/Acura B18A B18B B20B B20Z 1.2-1.8 8mm
Part # ARP208-6001
20$ Paypal PM ME
