new at the engine swaps
Discussion in 'Accord' started by bankz0185, Feb 21, 2008.
Thread Status:
Not open for further replies.
  1. bankz0185
    bankz0185 New Member
    ok i have a 91 5spd accord lx coupe and i want to put the h22a in and turbo it, is i never done this before my first car was 89 carb accord then i got this one, the question besides all the ecu's wiring har. the engine n block is, can the h22a bolt up to the stock trany or should i jus go with the lsd trany? and can i use the stock axles or do i have to upgrade the axles?basicly im lookin for advise to make this swap easier n less problems and im not lookin for bullshit comments or anything im jus looking for help thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if you want you can use your stock tranny and all for the h22a,, but if you want better tranny go with the h22a tranny
  3. bankz0185
    thanks wat about the axles?
  4. AHHVTEC
    Alabama
    you can use the stock axles also, you will just need to take the half shaft off the accord motor and put it on the h22a motor
  5. bankz0185
    ok so basicly i can use almost everything on the accord mtor on tha h22? and is it gunna b bitch running the wiring and ecu?
  6. AHHVTEC
    Alabama
    its a easy swap, just use your stock harness and add the wires you dont have witch will only be like 3
  7. bankz0185
    really wow thanks for your time to answer my questions
  8. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    actually what i found out is that the wires are way off, and you will have to relocate all the wires besides two. the easiest way to do it is going to hasport, they charge 299$ it takes em about 2 weeks to build. you will have to send in your stock accord engine harness(or another one from a junkyard or something) and the h22 engine harness, and they will send you one back so it will be plug and play. so you drop it in, clip it up, and go
  9. cloud198407
    cloud198407 New Member
    Hey I was reading your question and just wanted to let you know you should use a h22 transmission or you will be changing it out quickly, the stock accord tranny want take much abuse, I know from experience.
  10. AHHVTEC
    Alabama
    you should change your letters to black
  11. BrutalB83
    Rochester Hills, MI
    :werd:
    The light blue is hard to read...
  12. Uncle Buck
    Uncle Buck JDMDecals.com guru
    Spearfish, South Dakota
    and it makes you look like a fairy..... well kinda like Brutal :D
  13. BrutalB83
    Rochester Hills, MI
    :redface:
  14. fallens425
    fallens425 New Member
    i have a 87 carb accord, and am looking to do an engine swap... depending on how cheap i can do it. anyone have any fuel injected engines?
  15. BrutalB83
    Rochester Hills, MI
    Are you just looking to upgrade to an injected Accord engine from the 80s? Or are you wanting to do like a B18/H22 swap?
  16. eg6sir
    u should start your own thread.. this one is over 3 yrs old
Thread Status:
