new biuld w/ pic's
Discussion in 'Auto Multi-Media' started by smooth_criminal, Nov 29, 2005.
  1. smooth_criminal
    smooth_criminal Senior Member
    My current project
    B18b1 block / head going into a 96 LX civic 4dr
    This is were I started
    Act clutch
    Head studs
    Block wiesco pistons / Eagle H-beam “esp” rods / clevite h-series rod bearings / ACL race mains
    Stock Honda cup holder
    Socketed ECU / datalogging cable
    Walbro 255 fuel pump
    HASport AC mount
    Head gasket / timing belt
    Torque mount inserts
    Misc Honda seals / gaskets / grommets / OBD coversion harness / AN oil fittings / ball joint
    Avid Mounts (courtesy or Eric (simplegreen) over on Civicland )
    LC-1 Wideband O2 sensor / ECU monitoring
    ITR Oil pump / ITR water pump
    No name gauge pod
    New charge piping / Greddy Type – s BOV
    Valve cover
    This is the progress so far on the block assembly
    Still waiting for a bunch of shit
    Crower dual stage valve springs
    Crower Titanium retainers
    Catch can
    Breather tank
    D1 Vacuum manifold
    D1 Cam seal / cap
    D1 Map sensor flange
    GM 3 bar map sensor
    Rc 440cc injectors
    DC sport short shifter
    And a lot more that i can't think of right now, Pic’s will be posted as parts arrive / are installed
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Niiiiiice
  3. noobvang
    noobvang Senior Member
    Twincities, MN
    NICE!!!
    Keep the pics coming.
    And also, how much was that cup holder?
  4. pissedoffsol
  5. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    Ummmmm [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Very nice Good Luck and keep those pics coming.
  6. formby
    formby learning in progress
    nice job.....
    where did you get the charge piping????? i need a set
  7. Celerity
    Celerity Well-Known Member
    All that for $3400 ? Score ! tha'ts actually not bad at all.
  8. smooth_criminal
    Cup holder was 27 from honda, I had to order it, I've been looking at the hole wereit belongs inside the car for 4 years.
    Charge piping i order for Ebay, Piping is actually damn nice, great beads good heat dispancement (so says the paperwork) the only thing is the flange is alittle thin, It's solid and strong but with the flange on the BOV being as think is it is it kinda looks funny.
    I spent about 4200 so far (thats including $690 for the machine shop) have about another 3-500 i still need to spend to finish it up the way i want.
    Just got some more boxes of shit today, i'll post pics later.
  9. 92civicb18b1
    92civicb18b1 The Trisexual
  10. pissedoffsol
  11. brian11to1
    brian11to1 Senior Member
    very bad ass looking build.
    good luck building!
  12. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Nice lookin goodies. WAAAAAAAAAAAAAAAAAAAAAAPSHHHHHHHHHHHHHHHHH
  13. 92dxhatch
    92dxhatch Senior Member
    nor*cal
    SWEETNESS, looks like you fell into an early christmas [​IMG]
  14. ripperbone
    ripperbone angry bear
    Oklahoma
    very nice :thumbsup:
    when did avid start to make billet motor mounts [​IMG]
  15. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
  16. phunky.buddha
    Dallas / Fort Worth, TX
    Dang... don't just cut/paste your posts! Remember that "simplegreen" doesn't exist here. You need a HondaSwap sticker too. :)
  17. B16
    B16 Super Moderator VIP
    yay area, CA
    Did you already buy your RC440's? If not, I have some RC 550 peak holds I need to get rid of.
  18. Cashizslick
    nice dude.
    what size turbo you going to run on that?
  19. brian11to1
    ACL H Series main bearings... Like, H22 bearings? Please elaborate..
  20. pissedoffsol
